I tried to configure a XMC1300 to work in SPI-Slave-Mode by setting the USIC-registers in this way:
(since I just want to receive data, I didn't initialise the data output pin)
#include
void USIC0_Init(void)
//Kernel State Configuration Register - Module Enable + Bit Protection for MODEN
USIC0_CH1->KSCFG |= (1 << USIC_CH_KSCFG_MODEN_Pos) | (1 << USIC_CH_KSCFG_BPMODEN_Pos);
//Configuration of USIC Input Stage
WR_REG(USIC0_CH1->DX0CR, USIC_CH_DX0CR_DSEL_Msk, USIC_CH_DX0CR_DSEL_Pos, 1); //MOSI: P1.2
WR_REG(USIC0_CH1->DX0CR, USIC_CH_DX0CR_INSW_Msk, USIC_CH_DX0CR_INSW_Pos, 1);
WR_REG(USIC0_CH1->DX1CR, USIC_CH_DX1CR_DSEL_Msk, USIC_CH_DX1CR_DSEL_Pos, 1); //SCKL: P0.8
WR_REG(USIC0_CH1->DX1CR, USIC_CH_DX1CR_INSW_Msk, USIC_CH_DX1CR_INSW_Pos, 1);
WR_REG(USIC0_CH1->DX2CR, USIC_CH_DX2CR_DSEL_Msk, USIC_CH_DX2CR_DSEL_Pos, 1); //SS: P0.9
WR_REG(USIC0_CH1->DX2CR, USIC_CH_DX2CR_INSW_Msk, USIC_CH_DX2CR_INSW_Pos, 1);
//Configuration of USIC Shift Control
//Transmission Mode (TRM) = 1
WR_REG(USIC0_CH1->SCTR, USIC_CH_SCTR_TRM_Msk, USIC_CH_SCTR_TRM_Pos, 1);
//Configuration of Channel Control Register
WR_REG(USIC0_CH1->CCR, USIC_CH_CCR_MODE_Msk, USIC_CH_CCR_MODE_Pos, 1);
WR_REG(USIC0_CH1->CCR, USIC_CH_CCR_AIEN_Msk, USIC_CH_CCR_AIEN_Pos, 1);
uint32_t buffer = 0;
while(1)
buffer = USIC0_CH1->RBUF0;
//buffer = USIC0_CH1->RBUF1;
return 0;
Unfortunately, I can't receive the data I'm sending with a PIC24F by Microchip (Master)...
I watched the USIC-registers while debugging and after the PIC had sent 0xAA they looked like this:
http://s14.directupload.net/file/d/3331/tzwxadmk_jpg.htm
according to the RBUFSR (RBUFSR01) register, a "protocol related error" occured but what's that supposed to mean?
Maybe I forget something in my USIC settings...
Can anybody help me?
Hi TomTurbo,
From your initialization, everything looks alright.
Did you disable the clock gating of the USIC module?
You should have something like the below code before calling USIC0_Init();
SCU_GENERAL->PASSWD = 0x000000C0UL;
SCU_CLK->CGATCLR0 |= 0x00000008; // disable USIC clock gating
while((SCU_CLK->CLKCR)&0x40000000UL);
SCU_GENERAL->PASSWD = 0x000000C3UL;
USIC0_Init();
rgds,
Rou
Hi Rou,
thanks for the hint, I forget those clock seetings...the XMC received something but the errors are still the same:
223.attach
Regardless of what I'm sending, the values of RBUF and RBUF0 are always 0x1:confused:
Hi TomTurbo,
Instead of reading directly from RBUF0 or RBUF1, I would suggest you to read from RBUF only.
Perhaps something like this:
while((USIC0_CH1->PSR_SSCMode & USIC_CH_PSR_SSCMode_AIF_Msk)==0); // Wait until alt. received flag is set
USIC0_CH1->PSCR |= USIC_CH_PSR_SSCMode_AIF_Msk; // Clear flag
buffer = USIC0_CH1->RBUF;
rgds,
Rou
