XMC™ Forum Discussions
User20173
First solution authored
Hello ))
What I do:
f_mount(&fs, "0", 1); returns always "OK", and f_open/f_write work fine, addressing floders and files present on SPI.
f_mount(&fs, "1", 1); returns "OK" only when SD-card is inside the slot, so I am sure, that "1" is correct address of SD Card.
But the following call of f_open/f_write does the same as with SPI: it address file structures and creates files present on SPI.
If I take SD card after and connect to PC with cardreader, I see there is no change.
How to explicitly tell f_open() function to address SD, and not SPI??
Is there any input parameter, or a filed inside FIL structure?
Update:
I try to call it:
res = f_open(&fil, "1:xmc4800/hello.txt", FA_CREATE_ALWAYS | FA_WRITE | FA_READ);
but the resultis Invalid-Drive!
so, f_mount(&fs, "1", 1); returns OK,
but f_open with a path startin with "1:.. return invalid drive... hm...
User20173
This code is working fine, question closed.
void testSD()
FATFS fs; /* File system object (volume work area) */
FIL fil; /* File object */
FRESULT res; /* API result code */
UINT bw,br; /* Bytes written */
char buff[20];
res = FR_OK;
DSTATUS status = disk_initialize(0);
if (status!=0)
printf(status);
//return;
/* Register work area */
res = f_mount(&fs, "0", 1);
if (res == FR_OK)
/* Create a new directory */
//res = f_mkdir("XMC4800");
if ((res == FR_OK) || (res == FR_EXIST))
// test read-dir
DIR dp;
char* path="0:xmc4800";
res=f_opendir(&dp, path);
if (res == FR_OK)
FILINFO fno;
res=f_readdir(&dp, &fno);
if (res != FR_OK)
return;
res=f_closedir(&dp);
/* Create a file as new */
const char* ptr ="0:/hello.txt";
res = f_open(&fil, ptr, FA_CREATE_ALWAYS | FA_WRITE | FA_READ);
/* Write a message */
res = f_write(&fil, "Hello, World!\r\n", 15, &bw);
if (res == FR_OK )
res = f_lseek(&fil, 0);
/* Read the buffer from file */
res = f_read(&fil, &buff[0], 15, &br);
if(res == FR_OK)
/* Go to location 15 */
res = f_lseek(&fil, 15);
if(res == FR_OK)
/* Add some more content to the file */
res = f_write(&fil, "\nWelcome to Infineon", 20, &bw);
if(res == FR_OK)
f_close(&fil);
res = f_unmount("0");
User20173
void testSD()
char buff[20];
res = FR_OK;
if (status!=0)
printf(status);
//return;
if (res == FR_OK)
// test read-dir
DIR dp;
if (res == FR_OK)
FILINFO fno;
if (res != FR_OK)
return;
if (res == FR_OK )
if(res == FR_OK)
if(res == FR_OK)
if(res == FR_OK)
f_close(&fil);
Vasanth
Thanks for sharing the solution to the community.
Vasanth
