Rhohentanner
I have one of the USIC channels setup an SPI master and is connected to several different SPI slaves. The SCLK idle state is set to high, but when ever I call SPI_MASTER_DisableSlaveSelectSignal(&SPI_MASTER_0);, the SCLK idle state changes to low and I'm not sure why this is happening.
Pradeep_PN
50 likes received 250 sign-ins 100 solutions authored
Hi @Rhohentanner ,
We are checking on this meanwhile can you please tell us which device are you using ?
Best Regards
Pradeep.
Hello Pradeep, we are using the XMC4108.
Thanks, Rob
Pradeep_PN
Hi @Rhohentanner ,
We have tried your issue at our end but unable to recreate the issue and it is working fine.
As you mentioned there there are multiple slaves, We believe there is a particular slave that is causing this issue.
Can you try with each slave and find which causing the issue.
If possible please share the project and set up to recreate the issue at our end.
Best Regards
Pradeep.
