Rhammad
First reply posted First like received First question asked
I would to know what would be an alternative to SAF-XC167CI-16F40F BB for new designs ,that does not require significant code changes.
sujatapatil
250 replies posted 50 solutions authored 10 likes received
Hi @Rhammad ,
We have below alternative but it is not pin to pin replacement and would need code change .Please see below link
https://www.infineon.com/cms/en/product/microcontroller/32-bit-industrial-microcontroller-based-on-a...
Sujata
I just need to know what would be a non obsolete direct replacement to that MCU.
Electrical Engineer IV
Textron Systems
Electronics Systems
sujatapatil
Hi @Rhammad ,
Sujata
Hi Sujata,
Thanks for the info,would the code changes be related to the I/O pin out or would they be more involved than that because this alternative is an ARM Cortex MCU.
sujatapatil
Hi @Rhammad ,
Code changes will be not related to just IO pin , it would need some effort to port to new device.
If you are planning XMC  you need to take below approach.
1> XMC controller provides huge peripheral example code, pick most relevant code example for your application.
2> Identify all peripherials in your current project. configuration of peripherial is easy with our tool . Add driver for those using our tool  .
3> Last your main application which does actual business with these peripheral migrate .
Let me know if you have any doubt . Also let me know about your project , business opportunity to provide our support in porting.
Sujata
