PierceBoughton
First like given 5 sign-ins First reply posted
I recently purchased an XMC4700 Relax Kit. For my project, I am using Dave IDE. I have a PC which will be sending high frequency UDP messages via ethernet to the microcontroller. I need my microcontroller to note the time that the messages are received and deliver that information to another PC via USB cable. Alternatively, the time could be saved to an SD card on the microcontroller if that is easier.
I've never used Dave IDE before so any guidance would be appreciated.
ncbs
500 replies posted 50 likes received 250 sign-ins
Hi @PierceBoughton,
I am attaching the Getting started with DAVE Appnote. Refer to that for starting with DAVE. I also recommend you to refer to our code example database: https://www.infineon.com/cms/en/product/promopages/aim-mc/dave_downloads.html
Let me know if this helps you.
Nikhil
Hi Nikhil,
Thanks for your reply.
I've already followed the Getting started with DAVE notes. I've also looked through some of the code examples previously but haven't found anything to assist with my particular problem.
I'm hoping to find some sample code that uses udp for sending or receiving messages.
Pierce
