XMC™ Forum Discussions
Hi there,
I collect data from IIC transmission into FIFO on the XMC1100 and try to read after complete reception with a 'for' loop into an array. Obviously the loop is too fast for the FIFO. I can only get all data if I add a loop to reduce speed.
Is there a better way to handle this?
chismo
First like received
Is the 'for' loop started only after all the data are received in the FIFO? If so, it should not be a problem.
Min Wei
thanks for your response. I will check this. I may not have payed enough attention to the fact that I use a very slow baudrate.
