Is 32-bit I2S PCM supported by XMC4500 ? The maximum supported Word Length is 16-bits only.
So, how should we Read/Capture 24-bit I2S MIC data ? We have interfaced an I2S MIC, INMP441 with
XMC4500, which gives 24-bit PCM. So, how to read Data ? We have used FIFO & DMA without any success.
Please urgently, provide us example for reading 32-bit PCM using DAVE 4.
This thread is a duplicate of https://community.infineon.com/t5/XMC/XMC4500-32-bit-I2S-PCM-support/td-p/355542. Further replies will be done on that thread.
Vasanth
Vasanth
