03:58 AM
Nov 09, 2014
03:58 AM
06:24 PM
Nov 09, 2014
06:24 PM
Hi prathibha,
You never specify how you want the relay to turn on/off or even how your relay can be turn on.
Your question is too general and did not clearly explain what you really want.
I think this is very hard for anyone who would like to help you.
Nevertheless, since you can turn on and off your relay with toggle IO pin, you can also use PWM to turn on and off the relay.
If you are looking for DAVE Apps, you might want to look at PWMSP001.
10:13 PM
Nov 11, 2014
10:13 PM
Thank ROU,
I want to on relays through GPIOS,i am using IO004_set to on relay.IO004_Reset to off relay other than this is their any dave apps are their to turn on/off relays using
GPIOS.
Prathibha
GPIOS.
Prathibha
10:20 PM
Nov 11, 2014
10:20 PM
Hi prathibha,
IO004 is the only app to directly control the GPIO.
If you want to turn on/off the relay with PWM, you could try Rou suggestion by using PWMSP001 app and connect the PWM output pin to your relay.
01:03 AM
Nov 12, 2014
01:03 AM
thank you Jackson
Best Regards
Prathibha
Best Regards
Prathibha
