RTR
Murali1
10 questions asked 10 sign-ins First like given
We understood the concept but we are not able to configure RTR bit in code can you please explain how to configure RTR bit to reeive Remote frame in generated CAN_NODE_0.
sujatapatil
50 solutions authored 10 likes received 100 sign-ins
Hi Murali,
Do you see RXPND is set? If yes then please check below setting is enabled ?
 CAN_MOFCRn.RMM = 1;
Sujata
sujatapatil
Hi @Murali1
Please refer  https://www.infineon.com/dgdl/Infineon-MultiCAN-XMC4000-AP32300-AN-v01_00-EN.pdf?fileId=5546d4624e76... (page 16/ 17, transmit/receive process) you can find the registers need to be set in order to send /receive remote frames.
Below call will enable RTR frame receive,
CAN_NODE_MO_ClearStatus(HandlePtr1->lmobj_ptr[2], XMC_CAN_MO_SET_STATUS_RX_ENABLE | XMC_CAN_MO_SET_STATUS_MESSAGE_DIRECTION)
Sujata
Murali1
Above API is also used ,it set DIR bit but still i am not able to Receive RTR request  is there any configuration to receive remote frame(RTR) .
sujatapatil
Hi Murali,
 CAN_MOFCRn.RMM = 1;
Sujata
