bluefish97
10 sign-ins 5 questions asked 5 replies posted
I am trying to implement the "OTW_Firmware_Upgrade" program in my XMC7100 Lite v1 board. I have implemented Lcs and is able to access other sample programs.
When I try to implement "OTW_Firmware_Upgrade". I get the error:
 Status: failed
 [1]: there was an error retreiving the asset 'https://github.com/mcu-tools/mcuboot' commit 'v1.9.1-cypress' - Cloning into 'v1.9.1-cypress'..., fatal: unable to access 'https://github.com/mcu-tools/mcuboot/': SSL certificate problem: unable to get local issuer certificate, command 'C:/Users/<user>/ModusToolbox/tools_3.2/modus-shell/bin/bash -c git -C C:/Users/<user>/mtw/secureboot/mtb_shared/mcuboot clone --origin cypress --no-checkout --filter=blob:none https://github.com/mcu-tools/mcuboot v1.9.1-cypress', directory 'C:/Users/<user>/ModusToolbox/tools_3.2/dashboard', child process exited with error code 128
 [2]: Project 'bootloader_cm0p' in application directory 'C:/Users/<user>/mtw/secureboot/OTW_Firmware_Upgrade' - the getlibs operation failed
 [3]: Project 'dfu_cm7' in application directory 'C:/Users/<user>/mtw/secureboot/OTW_Firmware_Upgrade' - the getlibs operation failed
Also when I checked the "./lcs-manager-cli --list", I am able to see the files
"mcuboot v1.8.1-cypress" and 5 other older versions.
mcuboot v1.7.2-cypress
mcuboot v1.7.0-cypress
mcuboot v1.6.1-cypress
mcuboot v1.5.0-cypress
mtb-example-xmc7000-otw-firmware-upgrade        latest-v2.X
mtb-example-xmc7000-otw-firmware-upgrade        latest-v1.X
mtb-example-xmc7000-otw-firmware-upgrade        release-v2.0.0
mtb-example-xmc7000-otw-firmware-upgrade        release-v1.1.0
mtb-example-xmc7000-otw-firmware-upgrade        release-v1.0.0
How do I resolve this error without accessing the online github and run the program locally using
the local content storage ?
ps: I have enabled the environment variable "MTB_USE_LOCAL_CONTENT=true".
best,
PA
Daniyal_S
First like given 5 solutions authored 10 replies posted
Hey PrasadA,
Could you please refer to the readme of XMC7000: OTW firmware upgrade and fulfil the Requirements of the example code?
Thanks and Regards,
Daniyal Shaikh
Daniyal_S
Hey PrasadA,
Thanks and Regards,
Daniyal Shaikh
