Hello there,
We are working on bring-up of our custom board based on XMC4400 and wanted to know if we can program our custom boards using XMC4400Platform2Go kits.
We are thinking of connecting our custom boards JTAG signals to X102 on Platform2Ko kit. Will this work OK? Will do not see a way to isolate the JTAG signals going U1(XMC4400) on the Platform2Go kit.
- programming
Can you use the XMC Link ? I think it's a better solution than using the onboard debugger of the XMC4400Platform2Go. Technically, you can put multiple devices on the same TCK / TMS / TRST but with the X102 I do not think it's "plug and play", depending on your schematic, you should avoid it.
If you do, I suggest not connecting direct JTAG connector but pin by pin (only what is necessary).
Best regards.
Best regards.
