11:46 PM
Aug 25, 2015
11:46 PM
i tried to build a UDP/IP connection without an RTOS. As a basis i used an example from Dave "Help – Install DAVE App / Examples / … - select the Dave Site “DAVE Project Library Manager", which is called “xmc4500_relaxkit_lwip_httpserver_netconn” and tried to build in an Connection without RTOS using the NO_SYS option in lwipopts.h.
I have a problem during the configuration of the Ethernet port (see image below). In the original program there are no problems.
With wireshark i only get one ARP Request from the µC and ping doesn`t work.
I just can`t figure out what i`m doing wrong.
The program is attached to this Thread. Can somebody help me with my problem?
I use an XMC4500 Relax Kit.
Kind regards
Andreas
Kind regards
Andreas
Aug 26, 2015
02:05 PM
Aug 26, 2015
02:05 PM
11:15 PM
Aug 26, 2015
11:15 PM
Hello Jesus,
thank you for the fast answer. My project is now working.
The only problem is, that after maybe 20 seconds i lose the connection. What should i do to run connection continuously?
Andreas
Andreas
Aug 27, 2015
05:20 AM
Aug 27, 2015
05:20 AM
Jun 15, 2016
07:58 AM
Jun 15, 2016
07:58 AM
Hello Jesus,
Using Dave4 IDE and latest updates,
I tried to adapt the xmc4500_relaxkit_lwip_httpserver_raw application you attached in this previous post
to run on XMC4400 Hexagon board, but I cannot make it build.
Aparently the link file "linker_script.ld" of the XMC4400 is not compatible (see error below)
Can someone tell me why ?
Eventually point me to an example of lwip use WITHOUT RTOS on XMC4400 ?
I just need to send UDP packets.
Any help is welcome
Jorge
Any help is welcome
Jorge
