02:55 AM
Jan 30, 2016
02:55 AM
Hi there,
I am trying to use unions in Dave but run in syntax problems. Here is the sample code
typedef union
{uint16_t a;
uint32_t b;
} Mem;
Mem->a=5; <--- ../Main.c:96:4: error: expected identifier or '(' before '->' token
the declaration seems to be ok, however I can not access the variable. Does anybody know, what I need to do?
thanks in advance,
Felix
typedef union
{uint16_t a;
uint32_t b;
} Mem;
thanks in advance,
Felix
06:25 PM
Jan 31, 2016
06:25 PM
smktec wrote:
Hi there,
typedef union
{uint16_t a;
uint32_t b;
} Mem;
thanks in advance,
Felix
This is a C programming topic. You can find your answer else where.
BR
Travis
