User10696
Level 4
Level 4
First solution authored
The XMC4500 has a Power Monitor Control register (PWRMON). In this register you can set the Threshold for the brownout detection as a 8 bit value.
I cannot find any information about the units of this value. What is the correct value to use? Why are different values required? Shouldn't Infineon set the value to warn before the controller starts working incorrectly?
User10696
Level 4
Level 4
Can someone from Infineon please answer this question!
jferreira
10 sign-ins 5 sign-ins First like received
It is 22.5mV, check EVRVADCSTAT register documentation in SCU chapter.
