User8819
Level 4
Level 4
When using POSIF in quadrature mode, using two A,B input signals, manual shows that 4 edges are counted in OUT0 clock signal. This is OK.
My question is, if I set PCONF.QDCM=1 (direction count mode) because I have only "one" input signal, the clock signal OUT0 will be produced on both rising and falling edge of the input signal? Manual does not show this particular case. I am observing that probably (excluding some other mistakes) only one edge is counted!? Is this possible?
Thank you
rum
