Processor card: KIT_XMC4400_DC_V1
Drive board: EVAL-M5-IMZ120R-SIC board.
Question: How to set absolute current limit in software for I-V, I-U and I-W?
Problem: we can drive the motor for 2s. However, the current of I-V/U/W keep increasing. then trigger the CTRAP ..
ispn:26461:1:0
ispn:5471:1:0
l1:314:1:0
XMC
- current limit
Hi @BlueSky ,
The current loop code in PMSM_FOC_EXAMPLE_XMC44 is linked as a library so we cannot access the variables within it.
Can you please try changing Kp( reduce) and Ki( reduce) values so that di/dt will be limited and a gradual rise in current will happen which can help in the reduction of the false trigger.
Could you please try changing the current amplifier gain and shunt resistance to increase the current limit if the board supports a higher current.
Krupashankar
Hi @BlueSky .,
We will not be able to set IU, IV, and IW maximum current limit as the reference is always set using Iq and Id current.
Please try changing the macro for setting the maximum current.
#define PMSM_FOC_CURRENT_MIN_VALUE (-32768) /** Minimum value of the current in Q15 format */
#define PMSM_FOC_CURRENT_MAX_VALUE (32767U) /** Maximum value of the current in Q15 format */
Krupashankar
Thanks @Krupashankar ,
Changed as per your suggestion. However, after compilation, the binary was not changed.. surprised.
Currently, the motor can move for 5 seconds. However, the IU/V/W keep increasing after power on, until the TRAP is triggered, because IU/V/W are too high.
Any suggestion?
Hi @BlueSky,
Yes, we have also tried it on our end yes we have seen that there is no change in binary as that part of code is not being called. We will contact our internal team to resolve this issue.
As PMSM_FOC_EXAMPLE_XMC44 is APP-based and it contains PMSM_FOC_LIB as a library linked as an object file, We recommend you to use https://www.infineon.com/cms/en/product/microcontroller/32-bit-industrial-microcontroller-based-on-a... this code can be used to customize a lot of features and gives more flexibility.
Krupashankar
@Krupashankar thanks.
Yes, Actually, I am using PMSM_FOC_EXAMPLE_XMC44 project as baseline to modified the motor parameter.. but still can't work well.
Hi @BlueSky ,
Krupashankar
