Dear Krup,
we would like to know the relationship between the /CTRIP and /Enable in the FOC software.
/Enable TP301A.15 on XMC4400 board
/CTRIP0 TP301A.13 on XMC 4400 board
/CTRIP0 is monitored by ISR. and /Enable is controlled by state machine. Can we describe the /CTRIP0 detection sequence as following.
Power ON. ----> Software will check /CTRIP0
Branch 1, if /CTRIP0 = GND, Set /ENABLE to high.
Branch 2, if / CTRIP0 = High, Set /Enable to Low, ( enable the invertor).
Question:
1. Does XMC4400 provide a filter for CTRIP0 detection? and what is the sampling rate if level detection? What is the filter value?
2. Will XMC4400 enable the invertor before detecting the /CTRIP0?
Finally, where can we find the documentation for this question? or we have to read the code? If we have to read the code, may advice which function?
XMC
Hi @BlueSky ,
XMC_CCU8_SLICE_CaptureInit(); -> initialize the CCU8 capture
XMC_CCU8_SLICE_CAPTURE_CONFIG_t -> Use this structure to configure pre-scaler to vary the filter time
XMC_CCU8_SLICE_SetPassiveLevel(); -> can be used to set the passive level of inverter pin.
CTRAP - will be initiated during interrupt initialization
CTRAP will be initialized and captured before inverter initialization
Krupashankar
Hi @BlueSky ,
Krupashankar
