Jiawei
5 replies posted 10 sign-ins 5 sign-ins
Hello everyone,
I want to use 'TLV493D-A1B6 MS2GO'. After reading the User Manual, I have downloaded and installed 'GUI for 3D Magnetic Sensor 2GO' and J-Link drive. But when I connected 'TLV493D-A1B6' to my PC and opened the J-Link Commander, it popup window which showed 'No emulators connected via USB'. As showed in the picture below:
Then, if I click 'Yes', it would show 'Connecting to J-Link via USB...FAILED: Cannot connect to J-Link.' like the picture below:
(My computer operating system is Windows 10.)
 It seems that my PC can't identify TLV493D-A1B6. And I don't know why the J-Link Commander can't find TLV493D-A1B6. Could you tell me how to connect to J-Link?
Best Regards
Jiawei
Owen_Su
250 solutions authored 500 replies posted 50 likes received
Hi, @Jiawei ,
    You should first check if your PC can recognize your device, open 'Device manager':
    If not, you should reinstall the J-LINK driver and check if you have powered up your board correctly.
BR,
Owen
Owen_Su
Hi, @Jiawei ,
BR,
Owen
Jiawei
Hi, @Owen_Su ,
Thanks for your reply. The problem I had has been solved.  I opened 'Device manager' and found my PC can't recognize my device. Then I checked the data cable. I found that my data cable can only power the device but can't transfer date. Therefore, I switched to another date cable and connected the device to my PC successfully.
Jiawei
