08:50 PM
Aug 21, 2013
08:50 PM
Dear ALL
i new too infineon and new too ARM M0
i in LED sale, field
i would like to use infinwon chip ARM M0
if i need to hire some company
use with infineon chip
could you please suggest where i can post, where can i contact,or what direction should,?
the main is would like to use
LED in development kit,
use with 1200, with BCCU,
scope like this
-design PCB fit require
-Use BCCU, with should be it great function
Via SMX is mainly
little add, Portrig
work with VC ++ .net about interchange data,
that is enough
waiting whom has merit suggest this
Thanks for all,
PSRI
scope like this
Via SMX is mainly
little add, Portrig
that is enough
Thanks for all,
PSRI
10:10 PM
Aug 25, 2013
10:10 PM
Hi, you can contact the respective Infineon regional office and I am sure they will response to you.
