we are developing custom board using XMC 4800.
Before, I used to use the micrium u/c probe.
but, u/c probe is changed to micro Inspector pro these days.
can i get a license?.
Thanks for your time.
Sincerely,
garam
Hi, @garam ,
Micro Inspector Pro in unregistered mode (without entering a license key) allows the complete usage of existing dashboards. So, if you just do some tests, you can directly use. If you want to use this app for commercial purposes, here I suggest you build a CASE in our case system, because it need your name/email address/company and some other information to get the license, and the license is just for yourself. Community is an open platform. If your license is placed here, it will be used by others. Thanks for your understanding.
Owen_Su
Hi, @garam ,
Owen_Su
