01:16 PM
Oct 08, 2017
01:16 PM
I followed the Infineon-Tooling_Micrium_uCProbe_XMC_getting_started-GS-v01_00-EN.pdf instructions and was able to get sliders and text controls working with the XMC 2go XMC1000 board. I am having trouble getting the Oscilloscope to work.
On page 27, I downloaded the target code Micrium-Probe-TargetCode-410.zip file and put the Scope folder in my project, added Scope to the compile path, and moved probe_scope_cfg.h from the cfg folder to the Scope folder.
Everything compiled without error.
I added an INT variable to the oscilloscope and ran it, and it remains grayed out. The slider control still works.
Does the Oscilloscope control work with the XMC1000? I tried using a double and a float variable type, and that didn't work either.
Any suggestions would be appreciated.
Bob
Bob
02:20 PM
Oct 08, 2017
02:20 PM
Fixed. The Micrium target code didn't seem to work. This post lead to a fix: This post had a link to a XMC4700 project which had the ProbeScope folder with the 3 files. That worked.
Oct 09, 2017
01:00 AM
Oct 09, 2017
01:00 AM
Alternatively you can use the UCPROBE APP from the contributed APPs repository (Help > Install DAVE APP/Example/Device Library ...)
