Manufacturer Part Number for L101 and L151 for XMC™ EtherCAT Phy Board Schematics Revision 1.4
Marcelo_Macedo1
10 replies posted 50 sign-ins 10 likes given
Can you please double check what is the MPN (Manufacturer Part Number) for the transformers L101 and L151 for the new "XMC™ EtherCAT Phy Board Schematic: Input and Output Phy (see Revision 1.4)". The schematic is on the page 23 of the document on below link. It's the schematic sheet name XMC_ECAT_PG-V2.1.
https://www.infineon.com/dgdl/Infineon-Board_User_Manual_XMC4700_XMC4800_Relax_Kit_Series-UserManual...
I'd guess it's the same MPN HX1260NL of the revision 1.3 at the page 21, but would like to confirm as the Ethercat PHY is different.
Marcelo Macedo
ncbs
500 replies posted 50 likes received 250 sign-ins
Hi @Marcelo_Macedo1 ,
I confirm that L101 and L151 are HX1260NL. The schematics shall be updated to reflect the MPN.
Nikhil
ncbs
The changes in the revision 1.4 have been summarized here:
Thank you for pointing out the missing MPN for L101 and L151. We are looking into it, and shall update you at the earliest.
Nikhil
ncbs
Nikhil
Marcelo_Macedo1
Could you get this information?
Marcelo
