bluefish97
10 sign-ins 5 questions asked 5 replies posted
Hi, I tried to implement the mtb-littlefs in my xmc7100D board  with few modification to mq serial-read/write program: But I am encountering an error: could you tell me why I am unable to do "
lfs_file_read(lfs, &file, &boot_count, sizeof(boot_count));
My COM Port:
in my lfs.c:
lfs_ssize_t lfs_file_read(lfs_t *lfs, lfs_file_t *file,
        void *buffer, lfs_size_t size) {
    int err = LFS_LOCK(lfs->cfg);
    if (err) {
        return err;
    LFS_TRACE("lfs_file_read(%p, %p, %p, %"PRIu32")",
            (void*)lfs, (void*)file, buffer, size);
    printf("lfs_file_read(%p, %p, %p, %"PRIu32")",
    LFS_ASSERT(lfs_mlist_isopen(lfs->mlist, (struct lfs_mlist*)file));
    lfs_ssize_t res = lfs_file_rawread(lfs, file, buffer, size);
    LFS_TRACE("lfs_file_read -> %"PRId32, res);
    LFS_UNLOCK(lfs->cfg);
    return res;
How do I solve the LS_ASSERT function from failing?
Also how do I verify little_fs is not mounted on the internal flash but on the inbuild external flash memory.
Best,
PrasadA
Yuvraj
First question asked 250 replies posted 25 likes received
May I know which flash family you are using?
Yuvraj
The flash is the inbuild external flash in XMC7100D:
I am using the library: mtb-little_fs (for psoc-6) slightly modified for XMC71000D.
main.c:
* File Name: main.c
* Description: This is the source code for the Serial Flash Read and Write example
* for ModusToolbox.
* Related Document: See README.md
* Copyright 2018-2024, Cypress Semiconductor Corporation (an Infineon company) or
* an affiliate of Cypress Semiconductor Corporation.  All rights reserved.
* This software, including source code, documentation and related
* materials ("Software") is owned by Cypress Semiconductor Corporation
* or one of its affiliates ("Cypress") and is protected by and subject to
* worldwide patent protection (United States and foreign),
* United States copyright laws and international treaty provisions.
* Therefore, you may use this Software only as provided in the license
* agreement accompanying the software package from which you
* obtained this Software ("EULA").
* If no EULA applies, Cypress hereby grants you a personal, non-exclusive,
* non-transferable license to copy, modify, and compile the Software
* source code solely for use in connection with Cypress's
* integrated circuit products.  Any reproduction, modification, translation,
* compilation, or representation of this Software except as specified
* above is prohibited without the express written permission of Cypress.
* Disclaimer: THIS SOFTWARE IS PROVIDED AS-IS, WITH NO WARRANTY OF ANY KIND,
* EXPRESS OR IMPLIED, INCLUDING, BUT NOT LIMITED TO, NONINFRINGEMENT, IMPLIED
* WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. Cypress
* reserves the right to make changes to the Software without notice. Cypress
* does not assume any liability arising out of the application or use of the
* Software or any product or circuit described in the Software. Cypress does
* not authorize its products for use in any products where a malfunction or
* failure of the Cypress product may reasonably be expected to result in
* significant property damage, injury or death ("High Risk Product"). By
* including Cypress's product in a High Risk Product, the manufacturer
* of such system or application assumes all risk of such use and in doing
* so agrees to indemnify Cypress against all liability.
* Header Files
#include "cycfg_qspi_memslot.h"
#include "cyhal.h"
#include "cybsp.h"
#include "cy_retarget_io.h"
#include "cy_serial_flash_qspi.h"
#include <inttypes.h>
#include <string.h>
#include "lfs.h"
#include "lfs_spi_flash_bd.h"
/* FreeRTOS headers */
#include "FreeRTOS.h"
#include "task.h"
* Macros
#define PACKET_SIZE             (64u)     /* Memory Read/Write size */
/* Used when an array of data is printed on the console */
#define NUM_BYTES_PER_LINE      (16u)
#define LED_TOGGLE_DELAY_MSEC   (1000u)   /* LED blink delay */
#define MEM_SLOT_NUM            (0u)      /* Slot number of the memory to use */
#define QSPI_BUS_FREQUENCY_HZ   (50000000lu)
#define FLASH_DATA_AFTER_ERASE  (0xFFu)   /* Flash data after erase */
#define STORAGE_DEVICE_SD_CARD              (0)
#define LITTLEFS_TASK_STACK_SIZE            (512U)
#define USER_BUTTON_INTERRUPT_PRIORITY      (7U)
/* Debounce delay for the user button. */
#define DEBOUNCE_DELAY_MS                   (50U)
* Global Variables
static TaskHandle_t littlefs_task_handle;
static cyhal_gpio_callback_data_t user_btn_callback_data;
/* This enables RTOS aware debugging */
static volatile int uxTopUsedPriority;
* Function Prototypes
static void user_button_interrupt_handler(void *handler_arg, cyhal_gpio_event_t event);
* Function Definitions
* Function Name: check_status
* Summary:
*  Prints the message, indicates the non-zero status by turning the LED on, and
*  asserts the non-zero status.
* Parameters:
*  message - message to print if status is non-zero.
*  status - status for evaluation.
* Return:
*  void
void check_status(char *message, uint32_t status)
    if (0u != status)
        printf("\r\n=====================================================\r\n");
        printf("\nFAIL: %s\r\n", message);
        printf("Error Code: 0x%08"PRIX32"\n", status);
        /* On failure, turn the LED ON */
        cyhal_gpio_write(CYBSP_USER_LED, CYBSP_LED_STATE_ON);
        while(true); /* Wait forever here when error occurs. */
* Function Name: print_array
* Summary:
*  Prints the content of the buffer to the UART console.
* Parameters:
*  message - message to print before array output
*  buf - buffer to print on the console.
*  size - size of the buffer.
* Return:
*  void
void print_array(char *message, uint8_t *buf, uint32_t size)
    printf("\r\n%s (%"PRIu32" bytes):\r\n", message, size);
    printf("-------------------------\r\n");
    for (uint32_t index = 0; index < size; index++)
        printf("0x%02X ", buf[index]);
        if (0u == ((index + 1) % NUM_BYTES_PER_LINE))
            printf("\r\n");
    (void) handler_arg;
    (void) event;
    BaseType_t higher_priority_task_woken = pdFALSE;
    vTaskNotifyGiveFromISR(littlefs_task_handle, &higher_priority_task_woken);
    /* Yield if xHigherPriorityTaskWoken was set to true */
    portYIELD_FROM_ISR( higher_priority_task_woken );
static void print_block_device_parameters(struct lfs_config *lfs_cfg)
    printf("Number of blocks: %"PRIu32"\n", lfs_cfg->block_count);
    printf("Erase block size: %"PRIu32" bytes\n", lfs_cfg->block_size);
    printf("Prog size: %"PRIu32" bytes\n\n", lfs_cfg->prog_size);
static void increment_boot_count(lfs_t *lfs, struct lfs_config *lfs_cfg)
    uint32_t boot_count = 0;
    lfs_file_t file;
    /* Mount the filesystem */
    int err = lfs_mount(lfs, lfs_cfg);
    /* Reformat if we cannot mount the filesystem.
     * This should only happen when littlefs is set up on the storage device for
     * the first time.
    if (err) {
        printf("\nError in mounting. This could be the first time littlefs is used on the storage device.\n");
        printf("Formatting the block device...\n\n");
        lfs_format(lfs, lfs_cfg);
    /* Read the current boot count. */
    lfs_file_open(lfs, &file, "boot_count", LFS_O_RDWR | LFS_O_CREAT);
    /* Update the boot count. */
    boot_count += 1;
    lfs_file_rewind(lfs, &file);
    lfs_file_write(lfs, &file, &boot_count, sizeof(boot_count));
    /* The storage is not updated until the file_sd is closed successfully. */
    lfs_file_close(lfs, &file);
    /* Release any resources we were using. */
    lfs_unmount(lfs);
    /* Print the boot count. */
    printf("boot_count: %"PRIu32"\n\n", boot_count);
static void littlefs_task(void* arg)
    cy_rslt_t result;
    lfs_t lfs;
    struct lfs_config lfs_cfg;
    /* Step 1: Get the default configuration for the block device.
     * Step 2: Initialize the lfs_config structure to zero (not required if it
     *         is a global variable)
     * Step 3: Create the block device
     * Step 4: Print the block device parameters such as erase block size
     * Step 5: Perform file system operations to increment the boot count
#if(STORAGE_DEVICE_SD_CARD)
    lfs_sd_bd_config_t sd_bd_cfg;
    printf("Incrementing the boot count on SD Card...\n\n");
    /* Get the default configuration for the SD card block device. */
    lfs_sd_bd_get_default_config(&sd_bd_cfg);
    /* Initialize the pointers in lfs_cfg to NULL. */
    memset(&lfs_cfg, 0, sizeof(lfs_cfg));
    /* Create the SD card block device. */
    result = lfs_sd_bd_create(&lfs_cfg, &sd_bd_cfg);
    check_status("Creating SD card block device failed", result);
#else
    lfs_spi_flash_bd_config_t spi_flash_bd_cfg;
    printf("\nIncrementing the boot count on SPI flash...\n\n");
    /* Get the default configuration for the SPI flash block device. */
    lfs_spi_flash_bd_get_default_config(&spi_flash_bd_cfg);
    /* Create the SPI flash block device. */
    result = lfs_spi_flash_bd_create(&lfs_cfg, &spi_flash_bd_cfg);
    check_status("Creating SPI flash block device failed", result);
#endif /* #if(STORAGE_DEVICE_SD_CARD) */
    print_block_device_parameters(&lfs_cfg);
    increment_boot_count(&lfs, &lfs_cfg);
    /* Enable the user button interrupt */
    cyhal_gpio_enable_event(CYBSP_USER_BTN, CYHAL_GPIO_IRQ_FALL, USER_BUTTON_INTERRUPT_PRIORITY, true);
    printf("Press the user button to format the block device or press reset to increment the boot count again\n\n");
    /* Wait until the user button press is notified through the interrupt */
    while (true)
        if(1lu == ulTaskNotifyTake(pdTRUE, portMAX_DELAY))
            /* Debounce the button press. */
            vTaskDelay(pdMS_TO_TICKS(DEBOUNCE_DELAY_MS));
            if(!cyhal_gpio_read(CYBSP_USER_BTN)) { break; }
    /* User button is pressed. Format the block device. */
    printf("Formatting the block device...\n");
    lfs_format(&lfs, &lfs_cfg);
    printf("Formatting completed...\n");
    lfs_sd_bd_destroy(&lfs_cfg);
#else
    lfs_spi_flash_bd_destroy(&lfs_cfg);
    printf("Press reset to continue...\n");
* Function Name: main
* Summary:
*  This is the main function for CM4 CPU. It does...
*     1. Initializes UART for console output and SMIF for interfacing a QSPI
*       flash.
*     2. Performs erase followed by write and verifies the written data by
*       reading it back.
* Parameters:
*  void
* Return:
*  int
    cy_rslt_t result;
    /* This enables RTOS aware debugging in OpenOCD */
    uxTopUsedPriority = configMAX_PRIORITIES - 1;
    /* Initialize the device and board peripherals */
    result = cybsp_init() ;
    CY_ASSERT (result == CY_RSLT_SUCCESS);
    /* Initialize retarget-io to use the debug UART port */
    result = cy_retarget_io_init(CYBSP_DEBUG_UART_TX, CYBSP_DEBUG_UART_RX, CY_RETARGET_IO_BAUDRATE);
    /* Initialize the user button used for erasing the block device. */
    result = cyhal_gpio_init(CYBSP_USER_BTN, CYHAL_GPIO_DIR_INPUT, CYHAL_GPIO_DRIVE_PULLUP, CYBSP_BTN_OFF);
    /* Configure GPIO interrupt */
    user_btn_callback_data.callback = user_button_interrupt_handler;
    /* Configure & the user button interrupt */
    cyhal_gpio_register_callback(CYBSP_USER_BTN, &user_btn_callback_data);
    /* Enable global interrupts */
    __enable_irq();
    /* \x1b[2J\x1b[;H - ANSI ESC sequence for clear screen */
    printf("\x1b[2J\x1b[;H");
    printf("************* "
           "Littlefs File System on SD Card and QSPI NOR Flash "
           "************* \n\n");
    /* Create the user tasks. See the respective task definition for more
     * details of these tasks.
    xTaskCreate(littlefs_task, "Littlefs Task", LITTLEFS_TASK_STACK_SIZE,
                NULL, (configMAX_PRIORITIES - 1), &littlefs_task_handle);
    /* Start the RTOS scheduler. This function should never return */
    vTaskStartScheduler();
    (void) result; /* To avoid compiler warning */
    for (;;)
/* [] END OF FILE */
Best,
PA
Yuvraj
Looks like your query is already being discussed in the thread:  https://community.infineon.com/t5/XMC/Mtb-littlefs-in-XMC7100-external-flash/td-p/743057
You will get further assistance in parent thread https://community.infineon.com/t5/XMC/Mtb-littlefs-in-XMC7100-external-flash/td-p/743057
Yuvraj
