User20035
I just bought an OPTIGA Trust XMC 4800 IoT Connectivity Kit, and have just started going through some tutorials, such as for DAVE. There's a DAVE QuickStart Guide for how to make a LED blink using a generated PWM signal. I follow the instructions, and have tried to use both the "XMC4800 IoT Connectivity Kit" under Boards, as well as the XMC4800-F100x2048" under the "XMC4800 Series" option, but in both cases neither P4.0 nor P4.1 are available when assigning the PWM output (these are LED pins on the board). Has anyone encountered the same problem? Thanks!
