Is the source code for the KIT_XMC4400_DC_V1 board available? We want to use the board as a learning tool, but before reflashing it, I wantr to be able to get back to the factory default image.
ispn:5471:1:0
l1:314:1:0
XMC
Hello @billr ,
There is no public release code available for this board. Since this is to just get started with the kit for motor control, then you can use DAVE to build a new project on XMC4400 drive card and can adopt any of the XMC lib or example code available inside Dave code repo.
Request you to also go through the User Manual for more information.
Sai
Sai
Hello @billr ,
Sai
Sai
