08:05 AM
Aug 28, 2015
08:05 AM
12:11 AM
Aug 31, 2015
12:11 AM
Hi Kurt,
Yes, we have a published an example using the XMCLib on using the DMA for fast data transfer.
AP32290 - XMC4000 - General Purpose Direct Memory Access(GPDMA) - EN.
Chapter 7: Multi block transfer of VADC result registers to RAM for motor control
Link:
http://www.infineon.com/dgdl/Infineon-GPDMA-XMC4000-AP32290-AN-v01_00-EN.pdf?fileId=5546d4624e765da5...
Daryl
Link:
Daryl
02:05 AM
Aug 31, 2015
02:05 AM
Hi Daryl,
thanks a lot. This is a great AN. Is something similar available for the DMA Memory to DAC?
Kind regards
Kurt
Kind regards
Kurt
09:14 AM
Aug 31, 2015
09:14 AM
Hi Kurt,
Here's the Application Note on how to use DAC. Although a similar connection to DMA is not available, you can use it with the GPDMA Application Note to construct your example.
DAC Application Note:
http://www.infineon.com/dgdlc/en?dcId=8a8181663431cb50013431cb500b0000&downloadTitle=Infineon-DAC-XM...
Daryl
Daryl
