zelemar
First reply posted First like given First question asked
This is first my project with XMC and Dave and I  have an issue with interrupts on 1404 release configuration.
The project has 3 interrupts: SysTick, IRQ5 and IRQ7 used as RX interrupts for CAN node0 and CAN node1.
Debug version works as supposed to, when messages received on CAN interrupts are working. When I compile the release version of the same code, only SysTick works (LED blinking), but CAN interrupts don't work anymore.
Can somebody help me out with this issue?
Alakananda_BG
50 likes received 250 sign-ins 250 replies posted
Hi @zelemar ,
Do you have any interrupt-service-routines?
Any global variables that are modified out-of-sequence e.g. from within an interrupt-service-routine must be declared volatile otherwise the optimizer (used for release builds but not debug builds) might assume that the value has not changed and therefore not bother to re-read the variable.
Alakananda
Alakananda_BG
Hi @zelemar ,
Alakananda
I have a global variable. ISR routine modifies it and in the main loop depending on its value actions are taken.
I  have declared it as volatile and now it works.
Thank You.
