Feb 07, 2021
08:14 AM
Feb 07, 2021
08:14 AM
the following thoughts are based on reading the manuals of XMC4800 and the A/D converter chip TI ADS8910b (https://www.ti.com/lit/ds/symlink/ads8910b.pdf?ts=1612646628576&ref_url=https%253A%252F%252Fwww.goog...).
The ADS should be interfaced with Quad SPI interface from XMC, which is set as master. Unfortunately, the XMC provides 4 DATA_OUT lines, but not 4 DATA_INs, so it can transfer data to the ADS on four lines, but cannot read back any. As the XMC must be master (for reasons of: providing the CLK signal to the ADS), I wonder if interfacing such ADS chips are even considered to be used in Quad SPI mode from XMC. Or do I have to use single SPI then?
ErnieT
ErnieT
11:11 PM
Feb 08, 2021
11:11 PM
1st answer to myself: QuadSPI is half-duplex, so all lines are IN and OUT.
11:11 PM
Feb 08, 2021
11:11 PM
Feb 17, 2021
03:36 AM
Feb 17, 2021
03:36 AM
Hi Ernie,
Happy that you found your answer. Additionally there is once Dave apps based example available on Dave. Kindly check QSPI_EXAMPLE_XMC45 in the DAVE Project Library Manager (Help -> Install Dave app/Example/Device library).
Vasanth R S
Vasanth R S
