Hi team,
We are facing an issue regarding programming and debug port in XMC4108Q48K64BAXUMA1
Recently we are using this IC for designing. By observing in Evolution board we designed the debugging port. But we need to know that is there any dedicated pins for Debugging and programming.
Is any possibilities, We need a detail explanation of how the pins will work by using interfaces
Hi @Hithesh ,
As per my understanding, to answer your query I have come across the below image for SWDIO/SWDCLK pins in XMC 4100 datasheet -
As mentioned in page 24 of the datasheet, by Pn_HWSEL it is possible to select between different hardware “masters”(HWO0/HWI0). The selected peripheral can take control of the pin(s). Hardware control overrules settings in the respective port pin registers.
Also, please refer page 2151 of XMC 4100 reference manual regarding the different interfaces. Below is the image shared which explains the same -
I hope this helps. Please feel free to add here in case of any further query or in case I am missing any information. We would be happy to help.
Aashita
