Hi
I am using Infineon XMC4400 Controller and I am converting Basic CAN functionality to Full CAN functionality. I am facing difficulty in understanding Message Object allocation with LIST register- As per my knowledge-
- XMC4400 supports 64 Message object and each MO must be allocated to one of the LIST register.
- There are 8 LIST registers in MultiCAN module
- Using PANCTR we can update/modify/remove the Message object to/from the LIST
(Please correct me if I am wrong.)
So my question is Can we allocate all 64 MOs to single LIST register or is there is any limitation? I am not finding the clear explanation in reference Manual.
Legacy Microcontrollers
Hi @StanGilbertland ,
The 3 points which you have mentioned above are correct.
>>The answer is NO, you can allocate a maximum of 32 MOs to a single LIST register.
I have attached an image below for reference.
