Feb 19, 2019
06:13 PM
Feb 19, 2019
06:13 PM
Hi everyone.
I am doing LIN Master communication.
* Debug & Compiler : DAVE 4.4.2
* Target MCU : XMC4500
I want to send Synchronization Break in LIN Master communication.
However, LIN protocol can not be applied using UART App.
* Modify the uart_conf.c file : Fail
* Transfer after changing baudrate : Fail
* Transmission using IO Port : Fail
So I want to know how to send Synchronization Break in LIN Master communication.
First, I want to know if there is sample code or reference material.
Second, I wonder if it is possible using the UART_CONFIG app.
Thank you.
Thank you.
08:01 AM
Feb 21, 2019
08:01 AM
Infineon appnote section 3.4 LIN (Local Interconnect Network) and example code in section 5.4
https://www.infineon.com/dgdl/ap1612900_XE166_USIC.pdf?fileId=db3a3043183a9555011874ec63280e45
Infineon XMC4000 and XC2000 microcontroller contain the same USIC IP, so the example code can be placed in XMC code directly.
Feb 24, 2019
06:39 PM
Feb 24, 2019
06:39 PM
Thank you for your advice.
I solved this problem.
