01:56 AM
Aug 14, 2014
01:56 AM
I do need your help to init a XMC1200 for DMX transmitting without app's.
Bernd
Bernd
Labels
02:31 AM
Aug 14, 2014
02:31 AM
Hi Bernd,
You just need to init the USIC to UART and add in the necessary algorithm to make it work like a DMX transmitter.
02:46 AM
Aug 14, 2014
02:46 AM
Hi Jackson,
Thank you for your quick answer!
Here is my code but it doesnt work.
void Init_UART(){ //Kapitel 15
uint32_t* StatusFlag = (uint32_t*)AddressStatusFlag;
//Peripheral declaration
USIC0_CH1->KSCFG |= (1 << USIC_CH_KSCFG_MODEN_Pos) | (1<< USIC_CH_KSCFG_BPMODEN_Pos); //Kernel State Configuration Register
//Fractional Divider mode selected
WR_REG(USIC0_CH1->FDR, USIC_CH_FDR_DM_Msk, USIC_CH_FDR_DM_Pos, 2 );
//Step Value
WR_REG(USIC0_CH1->FDR, USIC_CH_FDR_STEP_Msk, USIC_CH_FDR_STEP_Pos, FDR_STEP); //467 256kbd @32MHz
//PreDivider for CTQ, PCTQ = 0, Denominator for CTQ, DCTQ = 16
WR_REG(USIC0_CH1->BRG, USIC_CH_BRG_PCTQ_Msk, USIC_CH_BRG_PCTQ_Pos, BRG_PCTQ); //0
WR_REG(USIC0_CH1->BRG, USIC_CH_BRG_DCTQ_Msk, USIC_CH_BRG_DCTQ_Pos, BRG_DCTQ); //18
WR_REG(USIC0_CH1->BRG, USIC_CH_BRG_PDIV_Msk, USIC_CH_BRG_PDIV_Pos, BRG_PDIV); //2
//Configuration of USIC Shift Control
//Transmit/Receive LSB first is selected, Transmission Mode (TRM) = 1, Passive Data Level (PDL) = 1
WR_REG(USIC0_CH1->SCTR, USIC_CH_SCTR_PDL_Msk, USIC_CH_SCTR_PDL_Pos, 1);
WR_REG(USIC0_CH1->SCTR, USIC_CH_SCTR_TRM_Msk, USIC_CH_SCTR_TRM_Pos, 1);
//Set Word Length (WLE) & FRame Length (FLE)
WR_REG(USIC0_CH1->SCTR, USIC_CH_SCTR_FLE_Msk, USIC_CH_SCTR_FLE_Pos, 7);
WR_REG(USIC0_CH1->SCTR, USIC_CH_SCTR_WLE_Msk, USIC_CH_SCTR_WLE_Pos, 7);
//Configuration of USIC Transmit Control/Status Register
//TBUF Data Enable (TDEN) = 1, TBUF Data Single Shot Node (TDSSM) = 1
WR_REG(USIC0_CH1->TCSR, USIC_CH_TCSR_TDEN_Msk, USIC_CH_TCSR_TDEN_Pos, 1);
WR_REG(USIC0_CH1->TCSR, USIC_CH_TCSR_TDSSM_Msk, USIC_CH_TCSR_TDSSM_Pos, 1);
//Configuration of Protocol Control Register
//Sample Mode (SMD) = 1, Stop Bit is selected, Sample Point (SP) = 2, Pulse Length (PL) = 0
WR_REG(USIC0_CH1->PCR_ASCMode, USIC_CH_PCR_ASCMode_SMD_Msk, USIC_CH_PCR_ASCMode_SMD_Pos, 1);
WR_REG(USIC0_CH1->PCR_ASCMode, USIC_CH_PCR_ASCMode_STPB_Msk, USIC_CH_PCR_ASCMode_STPB_Pos, 0);
WR_REG(USIC0_CH1->PCR_ASCMode, USIC_CH_PCR_ASCMode_SP_Msk, USIC_CH_PCR_ASCMode_SP_Pos, 9);
//TBIF is set to simplify polling
WR_REG(USIC0_CH1->PSR_ASCMode, USIC_CH_PSR_TBIF_Msk, USIC_CH_PSR_TBIF_Pos, 1);
//Configuration of Transmitter Buffer Control Register
WR_REG(USIC0_CH1->TBCTR, USIC_CH_TBCTR_LIMIT_Msk, USIC_CH_TBCTR_LIMIT_Pos, 0);
//Configuration of Channel Control Register
//Parity generation is disabled
WR_REG(USIC0_CH1->CCR, USIC_CH_CCR_MODE_Msk, USIC_CH_CCR_MODE_Pos, 2);
WR_REG(USIC0_CH1->CCR, USIC_CH_CCR_PM_Msk, USIC_CH_CCR_PM_Pos, 0);
//Data Pointer & Buffer Size for Transmitter Buffer Control - DPTR = 64, Size = 6
WR_REG(USIC0_CH1->TBCTR, USIC_CH_TBCTR_DPTRSIZE_Msk, USIC_CH_TBCTR_DPTRSIZE_Pos, 0x06000040);
*StatusFlag |= (1 << UART_INIT);
}//End < Init_UART_CLK >
//Step Value
