User11996
Hi.
All new XMC1xxxx devices are not running from Flash and not accept the SWD-Interface by default.
The only thing that the µC makes is: stay in the build in bootloader.
Is there a possibility to change the Boot Mode Index for ASC-BSL to SWD with a automated script
to use the devices ?
I need this for mass production purpose.
A manual connetion with memtool, changing the BMI for EVERY device (1K, 5k, and more) takes too much time.
Is there any tool to do this?
Segger JLink's (no matter which) didn't work.....
Eric1
Hi xmcuser17,
please have a look to this file:
https://www.infineon.com/dgdl/Infineon-TOOL_FlashProgrammers_XMC-TR-v01_00-EN.pdf?fileId=5546d462525...
We are working on an update e.g.
J-Flasher and XMC-Link are supporting BMI configuration also.
Best Regards
Eric
Is there a date for when this update will be released? Thanks.
