NA97
50 sign-ins 10 replies posted 25 sign-ins
when I go to properties it only provides me this option How to do optimisation or custom library addition in the properties under c/c++ built setting
Aashita_R
50 likes received 100 solutions authored 250 replies posted
Hi @NA97 ,
The easiest way is to edit the Makefile directly. You can add in the CFLAGS define:
CFLAGS=-Os
CFLAGS  is among the environment variables conventionally used to specify compiler options to a build system when compiling C and C++ code.
https://gcc.gnu.org/onlinedocs/gcc/Optimize-Options.html
Aashita
Aashita_R
Hi @NA97 ,
CFLAGS=-Os
Aashita
