How to connect and use External RAM??
Hey,
Could someone give me an advice how to connect external RAM to the External Bus Interface of the controller . What things have to be considered when using an external RAM. And how do i have to set up my project te get access to the external RAM or enable it?
regards
Travis
First solution authored Welcome! 500 replies posted
Hi, in general you have to take note of the EBU interface signals such as the Address/Data line, CS, CLK etc. Next you have to understand the datasheet of your selected device so that you can do the necessary configuration on the EBU. I cannot be specific here until you have a selected device.
Thanks for the information. But do i have to do any special settings in my project to enable the external RAM and to use it?
