I am beginner here, so I would like to ask how to check the value of a variable in debugging process? how do I know which register assigned the value of the variable in debugging process?
Travis
First solution authored Welcome! 500 replies posted
Go to debugger mode. Highlight a global variable which you want to monitor and mouse right click >> Add watch expression.
Please note that variable is not updated on real time, hence you have to suspense the debugger in order to see the update.
