I would like to use a position sensor (TLI5012B E5000 or TLI5012B E5020) for the project.
I need to know what parameters should be changed for applying my code.
Refer to the MCU XMC1404 there is an example code to read a motor position from the sensorless feature but I need to read a motor position from the TLI5012B E5020 sensor, Pls anyone help to share the example code or advice how apply parameters from the original software.
Hello @Arthit ,
TLI5012B E5020 is basically an angle sensor ( not a position sensor )
Kindly refer to this repository on Angle sensors : https://github.com/Infineon/TLE5012-Magnetic-Angle-Sensor
Sai
Hi psb,
Thank you for your share info
I don't understand the document.
Could you share XMC1000 series example code for the TLI5012B E5020 sensor or angle sensor which is related?
Hello @Arthit ,
Sai
