11:30 PM
Nov 01, 2015
11:30 PM
Hi, I am working on XMC4100 UART. I wanna change UART baudrate at run time.I wanna do these baudrate update in same function. This is my use case ..
Switch(Baudrate)
case 9600:
UART_Baudrate(9600);
Send("Baudrate at 9600 \n");
break;
case 115200:
UART_Baudrate(115200);
Send("Baudrate at 115200 \n");
break;
case 256000:
UART_Baudrate(256000);
Send("Baudrate at 256000 \n");
break
The baudrate which was set first (9600) is working fine. But when I am trying to update new baudrate, there is a mismatch. please help
Switch(Baudrate)
case 9600:
break;
case 115200:
break;
case 256000:
break
Nov 02, 2015
09:20 PM
Nov 02, 2015
09:20 PM
You have to ensure that the UART had complete transmission and receive, before you can change the baud rate.
09:58 PM
Nov 04, 2015
09:58 PM
Hi Travis, Thanks for the response. Got solution for this problem. I just had to check TX and RX idle status bits before updating the new baudrate.
02:42 AM
Feb 10, 2016
02:42 AM
could you please spell out which registers are you referring to? Do you mean PSR.RXIDLE and PSR.TXIDLE ?
Feb 10, 2016
07:31 PM
Feb 10, 2016
07:31 PM
Yes, these must refer to the bits PSR.RXIDLE and PSR.TXIDLE.
Min Wei
Min Wei
