wanglipeng00000
10 questions asked 25 sign-ins 10 likes given
Hi, I am using  a low-level resolution Encoder for the control of PMSM, and I have a question, how to calculate the speed accurately based on low-level resolution Encoder?
Owen_Su
250 solutions authored 500 replies posted 50 likes received
Hi, @wanglipeng00000 ,
     If you are using a low-level resolution encoder for the control of PMSM, accurately calculating the speed can be challenging due to the limited resolution of the encoder. Here are some methods you can refer to:
    1) Counting Method: This method involves counting the number of encoder pulses within a fixed time period, and then using the count to calculate the speed. The calculation can be done using the following formula:
    Speed = (Pulses per second) / (Pulses per revolution)
    Where Pulses per second is the number of pulses counted within the fixed time period, and Pulses per revolution is the number of pulses per revolution for the encoder.
    2) Period Measurement Method: This method involves measuring the time between two consecutive encoder pulses, and then using the period to calculate the speed. The calculation can be done using the following formula:
    Speed = (60 * Pulses per revolution) / (Period * Encoder resolution)
    Where Period is the time between two consecutive encoder pulses, and Encoder resolution is the number of pulses per revolution for the encoder.
     You can find more information about controlling PMSM on our website:
    https://www.infineon.com/cms/en/search.html#!term=PMSM&view=all
    Hope this can help you.
BR,
Owen
Owen_Su
BR,
Owen
