XMC™ Forum Discussions
Tim_Shih
Level 4
50 replies posted 50 questions asked 100 sign-ins
Level 4
Dear Receive,
How to build a selected file in DAVE 4.5...?!
I found there is a function that can be built a selected file but when I pressed it and no any response.
Please check the attached file...
Thank you so much.
Owen_Su
Moderator 10 replies posted 5 replies posted First like given
Hi, @Tim_Shih ,
    I take 'XMC1300_Blinky' as an example. When I finished coding the file 'main.c', I can use 'Build selected file' function to check if there is any programming error in this file.
    If there is no programming error in the file, the compilation is completed(the * sign in front of 'main.c' disappears); if there is a programming error, the error mark will be displayed on the error line.
NikhilChandra
First reply posted Welcome!
Hey @Tim_Shih ,
Do you observe any pop-ups or error messages while you perform the build selected files action?
Do you observe any logs in the console?
Nikhil
Tim_Shih
Level 4
Level 4
No !!! I checked the console. Nothing happen. That's why I asked this question.
Thank you so much.
Owen_Su
Hi, @Tim_Shih ,
Tim_Shih
Level 4
Level 4
ok, thank you.
