Feb 05, 2014
02:21 AM
Feb 05, 2014
02:21 AM
I have a hexagon kit (XMC4500 F144K1024 revision AB) with integrated J-link debugger.
Have until now been debugging through DAVE3, but now I need to do a release programming (testing a bootloader).
I'm not familiar with all the tools and abbreviations. But what I have found so far is that i could:
1. Use infineon memtool:
Since I already have U0C0 connected did i try to use ASC BSL. But the program asks for a Target config file .cfg. I have no clue of how to generate or write one.
The same file is also requested if i choose DAS.
2. Use Segger J-link to download the hex into the MCU according to thread:
http://www.infineonforums.com/threads/1452-DAVE-TIP-of-the-day-How-to-use-SEGGER-J-Link-to-download-...
I don't have the folder or JFlashARM.exe. I assume that I need to download it from Segger. But they don't allow me to without a proper serial number for their device (which is not printed on the hexagon-kit).
Can anyone help me out?
11:33 PM
Feb 05, 2014
11:33 PM
To many hours by the keyboard...
Memtool did not ask me to open the cfg-file. It asked me where to save it... (memtool generated it)
Case closed.
Case closed.
05:37 PM
Feb 06, 2014
05:37 PM
Hi andersr,
So did you manage to program the Hex code into your XMC4500?
