I'm going to make my own webserver like the APP "HOT_XMC_HTTP_WEBSERVER".
This example works well now.
My question is: The user schould be able to change the MAC & IP address and restore it
in the FLASH Area via Internet Explorer.
How to realise it?
Thank you for help!
Bernd
User12775
Level 5
Level 5
First solution authored First like received
1.If you use DHCP, the ip address is allocated by the router in your LAN. You could manually assigned a static IP via the control panel of router configuration interface.
2.You could also disable the DHCP, and hard-code a IP address in the initialization routine.
Thank you for your answer!
Is there no chance to change the IP address of the "XMC4500 Relax Kit" after initialization?
Sorry, no ideas???
yes, you can.
User12775
Level 5
Level 5
1. Requested a new IP from DHCP.
2. Disable DHCP and help yourself a static IP.
