08:19 PM
Aug 28, 2017
08:19 PM
I was trying to use flash to simulate eeprom and get an example from keil examples.
but the examle didn't work.
I look into the debug and find out that whenever operate with the flash address ,the program goes into HardFault_Handler.
since i didn't change anything in the examle ,i wonder why it happens and how can i solve it?
08:37 AM
Aug 29, 2017
08:37 AM
You are using cortex M0, the address should be aligned at 4 byte boundary. It is the most possible cause.
Sep 06, 2017
01:02 AM
Sep 06, 2017
01:02 AM
Which example are you referring to?
