XMC™ Forum Discussions
User18369
I´m working with an XMC4300. Sometimes I have the problem that the uC end in a Hard Fault.
I have no clue what to do. I enabled Hard Fault debugging support in the CPU_CTRL_XMC4_0
My application : Using SPI to control a external Motor Controll Unit.
How can I find the cause of the Hard_Fault ?
jferreira
First like received 750 replies posted 500 replies posted
Have a look at the ARM Keil APP note on Using Cortex-M3/M4/M7 Fault Exceptions, http://www.keil.com/appnotes/docs/apnt_209.asp
