gargi1
25 sign-ins 10 questions asked 10 replies posted
Hi Team,
i want to implement trap signal in hrpwm app. can anyone please share some setup steps or example code for referance.
Thank,
Gargi
Pradeep_PN
250 sign-ins 100 solutions authored 25 likes received
Hi @gargi1 ,
Thanks for waiting.
Please refer to the attached project .
The HRPWM Output signals are routed to P0.6 and complimentary through P0.9 .
Whenever you press the User Button on The XMC 4400 Platform 2 Go Board (ie P3.2 ) You can observe that the PWM signals will be in its passible level (Low)
The Trap level is Active Low so whenever a Low Level is detected the TRAP function is triggered and it exit control is automatic which means when an active level is detected the System will be exited from Trap Function.
Hope this helps and let me know if you have any further queries.
Best Regards
Pradeep.
Pradeep_PN
Hi @gargi1 ,
Which device are you using ?
Are you expecting a DAVE example or Modus Tool Box example ?
Best Regards
Pradeep.
Hi Pradeep,
I am using xmc4400 platform 2go kit.
I am expecting Dave example.
Gargi
Pradeep_PN
Hi @gargi1 ,
I have successfully created a project in Modus Tool Box but facing some problems while working with DAVE, Please give some time i am working on this.
Best Regards
Pradeep.
gargi1
okay Pradeep
Pradeep_PN
Hi @gargi1 ,
Thanks for waiting.
Best Regards
Pradeep.
