XMC™ Forum Discussions
NarendraC
First solution authored 5 sign-ins First reply posted
I am finding below errors like groovy objects not found and problem occured while restoring the project data. but compilation is happening.
I just cloned the project from Git Repo.
kindly help in this
Narendra C
Vasanth
Could you check the suggestions in the following thread ?
1)It seems that the file was inadvertently added to the ignore-list of git.
We removed it manually by opening the /DAVE/Model/.gitignore file with the editor and delete the listed "projectData.bin" from this file.
2)I could resolve the issue using a tool named "Directory Compare", which I used to compare a checkout from GIT which showed the problem and a working local copy which was pushed to git. It turned out that several folders and .app files
were missing in the Dave directory. The Dave/Model/APPS/* directory was affected. I can recommend this tool to investigate this sort of issue. -> You may use tools like BeyondCompare too.
Vasanth R S
Vasanth
Vasanth R S
Hi
Thanks for the inputs,
 I found two .App files are missing from Dave/Model/APPS/ folder
So,Copied DIGITAL_IO_90.APP,SPI_CONFIG_0.APP files from previous commit.
Now project is building without any object groove errors.
But How does the .APP files misses?
Issue is fixed now
Narendra C
