Hello
I am Facing Error in serializing ModelConfigData.data file while setting up new Peripherals in SDK (infineon Microcontroller)
kindly help in solving this
XMC
Hi @Owen_Su
Thanks for the quick reply,
The error is resolved now after removing/adding multiple Digital_IO again one by one.
Narendra.C
Hi, @NarendraC ,
Can you tell us more details about what you are doing/ what you have set up, and also, you can check the log file to see the complete error log (or share with us). There are several reasons to cause this error, so we need more details about the warnings and errors. It will be great if you share your project with us, Thanks for your cooperation.
Owen_Su
Hi @Owen_Su
Narendra.C
