Aug 05, 2017
09:37 PM
Aug 05, 2017
09:37 PM
Hey everyone,
I'm a new XMC1100 user, and I'm trying to modify my linker script in DAVE to put all code in RAM. I modified the ".text" section to look like the ".ram_code" section, however, my program is restarting at the __copy_data branch instruction. I suspect I need to keep this startup code in text, but move everything else.
Does anyone have a linker script that loads all code into RAM, and then executes from there instead of flash?
I'm trying to get power consumption down, and I realized the memory capacity on this XMC1100 part is "backwards" — it has 16K of RAM, and 8K of flash 🙂
Thanks! Excited to get started with XMC!
Aug 05, 2017
09:50 PM
Aug 05, 2017
09:50 PM
XMC1100 has a cortex M0 core.
It will always start from Flash. If you would run the code in the RAM, you need to move the code into RAM and jump to it. Remember to remap the vector map.
Do you have an external storage device on your board. If not your code size is limited by the ROM size.
Aug 06, 2017
10:31 AM
Aug 06, 2017
10:31 AM
aurixuser wrote:
XMC1100 has a cortex M0 core. It will always start from Flash. If you would run the code in the RAM, you need to move the code into RAM and jump to it. Remember to remap the vector map.
Yes, I understand all this. But what are the specific changes I need to make to the linker file and startup file to implement this?
No external storage, but everything fits fine in flash and RAM. It's a tiny little program.
Aug 07, 2017
08:33 AM
Aug 07, 2017
08:33 AM
Split your program into two parts: a bootloader and an application. Each program occupy different space in the flash, and the two programs will generate two .hex files. You flash the two or a merged one into the flash.
The bootloader will load your application code from flash into RAM , remap the vector table, then jump to it.
Aug 09, 2017
02:45 AM
Aug 09, 2017
02:45 AM
I do not know how to do this in DAVE, but in IAR (for example) you just need to specify the prefix __ramfunc for the target function. Startup-code will copy it into RAM and just need to call it.
I think that in DAVE it is done similarly.
Aug 09, 2017
09:37 PM
Aug 09, 2017
09:37 PM
aurixuser wrote:
Split your program into two parts: a bootloader and an application. [...] The bootloader will load your application code from flash into RAM , remap the vector table, then jump to it.
Sure, but that's a ton of work. Why on earth doesn't someone just have a linker file that does this? Why reinvent the wheel?
Other platforms I've worked on have included example projects / linker files / start-up scripts for doing stuff like this. Given the fact that the XMC1100 has no intelligent flash prefetching and has to wait-state for anything above an 8 MHz clock — and then combine that with the fact that these parts have a whopping 16 KB of RAM — I feel like this would be super common for this platform. And you're telling me I have to write a freaking bootloader from scratch just to do this? That seems insane.
Yeah, sure, as I mentioned in my original post, there's a ".ram_code" section; I can explicitly decorate all of my functions, plus all of the DAVE code-gen functions, plus all the peripheral library functions... but that's a ton of work, and the moment I re-generate my code, it will all get erased.
Does Infineon monitor these forums? I posted this topic 4 days ago — sort of expected to get more official feedback by now.
Like I said, super new to Infineon / XMC stuff, and obviously this forum, too. Thanks for the help!
Aug 10, 2017
05:20 AM
Aug 10, 2017
05:20 AM
I only checked the .map file and did not execute this as I do not have the device XMC1100-T016F0008.
Please replace your linker_script.ld file with this:
* @file XMC1100x0008.ld
* @date 2017-04-20
* @cond
* Linker file for the GNU C Compiler v1.11
* Supported devices: XMC1100-T016F0008
* XMC1100-Q024F0008
* Copyright (c) 2015-2017, Infineon Technologies AG
* All rights reserved.
* Redistribution and use in source and binary forms, with or without modification,are permitted provided that the
* following conditions are met:
* Redistributions of source code must retain the above copyright notice, this list of conditions and the following
* disclaimer.
* Redistributions in binary form must reproduce the above copyright notice, this list of conditions and the following
* disclaimer in the documentation and/or other materials provided with the distribution.
* Neither the name of the copyright holders nor the names of its contributors may be used to endorse or promote
* products derived from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES,
* INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
* SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
* WHETHER IN CONTRACT, STRICT LIABILITY,OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* To improve the quality of the software, users are encouraged to share modifications, enhancements or bug fixes with
* Infineon Technologies AG dave@infineon.com).
* Change History
* 2015-07-07:
* - Product splitting
* - Copyright notice update
* 2015-11-24:
* - Compatibility with GCC 4.9 2015q2
* 2016-03-15:
* - Add assertion to check that region SRAM_combined does not overflowed no_init section
* 2016-10-28:
* - Fix linker not complaining if sum of data + text sections is bigger that physical FLASH size
* 2017-04-07:
* - Added new symbols __text_size and eText
* 2017-04-20:
* - Change vtable location to flash area to save ram
* @endcond
OUTPUT_FORMAT("elf32-littlearm")
OUTPUT_ARCH(arm)
ENTRY(Reset_Handler)
MEMORY
FLASH(RX) : ORIGIN = 0x10001000, LENGTH = 0x2000
SRAM(!RX) : ORIGIN = 0x20000000, LENGTH = 0x4000
stack_size = DEFINED(stack_size) ? stack_size : 1024;
no_init_size = 4;
SECTIONS
/* TEXT section */
.text :
sText = .;
KEEP(*(.reset));
/* M0 always executes from Flash after reset.*/
/* Only load necessary startup code here*/
*(.text.SystemInit .text.SystemCoreSetup .text.SystemCoreClockSetup .text.SystemCoreClockUpdate .gnu.linkonce.t.*);
/* C++ Support */
KEEP(*(.init))
KEEP(*(.fini))
/* .ctors */
*crtbegin.o(.ctors)
*crtbegin?.o(.ctors)
*(EXCLUDE_FILE(*crtend?.o *crtend.o) .ctors)
*(SORT(.ctors.*))
*(.ctors)
/* .dtors */
*crtbegin.o(.dtors)
*crtbegin?.o(.dtors)
*(EXCLUDE_FILE(*crtend?.o *crtend.o) .dtors)
*(SORT(.dtors.*))
*(.dtors)
*(.rodata .rodata.*)
*(.gnu.linkonce.r*)
*(vtable)
. = ALIGN(4);
} > FLASH
.eh_frame_hdr : ALIGN (4)
KEEP (*(.eh_frame_hdr))
} > FLASH
.eh_frame : ALIGN (4)
KEEP (*(.eh_frame))
} > FLASH
/* Exception handling, exidx needs a dedicated section */
.ARM.extab : ALIGN(4)
*(.ARM.extab* .gnu.linkonce.armextab.*)
} > FLASH
. = ALIGN(4);
__exidx_start = .;
.ARM.exidx : ALIGN(4)
*(.ARM.exidx* .gnu.linkonce.armexidx.*)
} > FLASH
__exidx_end = .;
. = ALIGN(4);
/* DSRAM layout (Lowest to highest)*/
/* Veneer <-> Stack <-> DATA <-> BSS <-> HEAP */
.VENEER_Code ABSOLUTE(0x2000000C):
. = ALIGN(4); /* section size must be multiply of 4. See startup.S file */
VeneerStart = .;
KEEP(*(.XmcVeneerCode));
VeneerEnd = .;
} > SRAM AT > FLASH
eROData = LOADADDR (.VENEER_Code);
VeneerSize = ABSOLUTE(VeneerEnd) - ABSOLUTE(VeneerStart);
/* Dummy section for stack */
Stack (NOLOAD) : AT(0)
. = ALIGN(8);
. = . + stack_size;
__initial_sp = .;
} > SRAM
/* Standard DATA and user defined DATA/BSS/CONST sections */
.data :
__data_start = .;
* (.data);
* (.data*);
*(*.data);
*(.gnu.linkonce.d*)
. = ALIGN(4);
/* preinit data */
PROVIDE_HIDDEN (__preinit_array_start = .);
KEEP(*(.preinit_array))
PROVIDE_HIDDEN (__preinit_array_end = .);
. = ALIGN(4);
/* init data */
PROVIDE_HIDDEN (__init_array_start = .);
KEEP(*(SORT(.init_array.*)))
KEEP(*(.init_array))
PROVIDE_HIDDEN (__init_array_end = .);
. = ALIGN(4);
/* finit data */
PROVIDE_HIDDEN (__fini_array_start = .);
KEEP(*(SORT(.fini_array.*)))
KEEP(*(.fini_array))
PROVIDE_HIDDEN (__fini_array_end = .);
__data_end = .;
} > SRAM AT > FLASH
DataLoadAddr = LOADADDR (.data);
__data_size = __data_end - __data_start;
.ram_code :
__ram_code_start = .;
/* functions with __attribute__ ((section (".ram_code")))*/
*(.ram_code)
/* All Default text code goes here */
*(.text .text.*)
__ram_code_end = .;
} > SRAM AT > FLASH
__ram_code_load = LOADADDR (.ram_code);
__ram_code_size = __ram_code_end - __ram_code_start;
__text_size = (__exidx_end - sText) + VeneerSize + __data_size + __ram_code_size;
eText = sText + __text_size;
/* BSS section */
.bss (NOLOAD) :
__bss_start = .;
* (.bss);
* (.bss*);
* (COMMON);
*(.gnu.linkonce.b*)
__bss_end = .;
. = ALIGN(8);
Heap_Bank1_Start = .;
} > SRAM
__bss_size = __bss_end - __bss_start;
/* .no_init section contains SystemCoreClock. See system.c file */
.no_init ORIGIN(SRAM) + LENGTH(SRAM) - no_init_size (NOLOAD) :
Heap_Bank1_End = .;
* (.no_init);
} > SRAM
/* Heap - Bank1*/
Heap_Bank1_Size = Heap_Bank1_End - Heap_Bank1_Start;
ASSERT(Heap_Bank1_Start <= Heap_Bank1_End, "region SRAM overflowed no_init section")
/DISCARD/ :
*(.comment)
.stab 0 (NOLOAD) : { *(.stab) }
.stabstr 0 (NOLOAD) : { *(.stabstr) }
/* DWARF 1 */
.debug 0 : { *(.debug) }
.line 0 : { *(.line) }
/* GNU DWARF 1 extensions */
.debug_srcinfo 0 : { *(.debug_srcinfo) }
.debug_sfnames 0 : { *(.debug_sfnames) }
/* DWARF 1.1 and DWARF 2 */
.debug_aranges 0 : { *(.debug_aranges) }
.debug_pubnames 0 : { *(.debug_pubnames) }
.debug_pubtypes 0 : { *(.debug_pubtypes) }
/* DWARF 2 */
.debug_info 0 : { *(.debug_info .gnu.linkonce.wi.*) }
.debug_abbrev 0 : { *(.debug_abbrev) }
.debug_line 0 : { *(.debug_line) }
.debug_frame 0 : { *(.debug_frame) }
.debug_str 0 : { *(.debug_str) }
.debug_loc 0 : { *(.debug_loc) }
.debug_macinfo 0 : { *(.debug_macinfo) }
/* DWARF 2.1 */
.debug_ranges 0 : { *(.debug_ranges) }
/* SGI/MIPS DWARF 2 extensions */
.debug_weaknames 0 : { *(.debug_weaknames) }
.debug_funcnames 0 : { *(.debug_funcnames) }
.debug_typenames 0 : { *(.debug_typenames) }
.debug_varnames 0 : { *(.debug_varnames) }
/* Build attributes */
.build_attributes 0 : { *(.ARM.attributes) }
* @date 2017-04-20
* @cond
* XMC1100-Q024F0008
* disclaimer.
* Change History
* 2015-07-07:
* 2015-11-24:
* 2016-03-15:
* 2016-10-28:
* 2017-04-07:
* 2017-04-20:
* @endcond
OUTPUT_ARCH(arm)
MEMORY
no_init_size = 4;
SECTIONS
/* TEXT section */
.text :
sText = .;
KEEP(*(.reset));
/* C++ Support */
KEEP(*(.init))
KEEP(*(.fini))
/* .ctors */
*crtbegin.o(.ctors)
*(SORT(.ctors.*))
*(.ctors)
/* .dtors */
*crtbegin.o(.dtors)
*(SORT(.dtors.*))
*(.dtors)
*(.gnu.linkonce.r*)
*(vtable)
. = ALIGN(4);
} > FLASH
} > FLASH
KEEP (*(.eh_frame))
} > FLASH
} > FLASH
. = ALIGN(4);
__exidx_start = .;
} > FLASH
__exidx_end = .;
. = ALIGN(4);
VeneerStart = .;
VeneerEnd = .;
} > SRAM AT > FLASH
. = ALIGN(8);
. = . + stack_size;
__initial_sp = .;
} > SRAM
.data :
__data_start = .;
* (.data);
* (.data*);
*(*.data);
*(.gnu.linkonce.d*)
. = ALIGN(4);
/* preinit data */
. = ALIGN(4);
/* init data */
. = ALIGN(4);
/* finit data */
__data_end = .;
} > SRAM AT > FLASH
.ram_code :
*(.ram_code)
*(.text .text.*)
__ram_code_end = .;
} > SRAM AT > FLASH
/* BSS section */
.bss (NOLOAD) :
__bss_start = .;
* (.bss);
* (.bss*);
* (COMMON);
*(.gnu.linkonce.b*)
__bss_end = .;
. = ALIGN(8);
} > SRAM
Heap_Bank1_End = .;
* (.no_init);
} > SRAM
/* Heap - Bank1*/
/DISCARD/ :
*(.comment)
/* DWARF 1 */
/* DWARF 2 */
/* DWARF 2.1 */
Jan 26, 2021
04:15 AM
Jan 26, 2021
04:15 AM
I want to do the same thing with an XMC1404-Q064X0200. Is there a proper linker script example for that too?
İpek
İpek
Feb 01, 2021
10:16 PM
Feb 01, 2021
10:16 PM
Hello Ipek ,
Posting this here for all users with similar questions. Kindly check the device guide. It has a section 4.3 Complete code execution from SRAM, with general instructions and sample code. If you are interested in a complete example,
please check the following source file. It contains the example linker file in Bootstrap loader\DAVE4\XMC1x_ASCLoader\XMC1x_ASCLoader.ld for execution from SRAM.
Vasanth
Vasanth
