May 27, 2021
07:48 AM
May 27, 2021
07:48 AM
Hello 🙂
I just have seen that the BCM5241XA1KMLG Ethernet transceiver used in the KIT_XMC48_RELAX_ECAT_V1 is discontinued.
Is there any recommendation from Infineon for a replacement if we start a new design?
Thanks in advance 🙂
Chris
Thanks in advance 🙂
Chris
- ethercat phy
12:57 AM
May 28, 2021
12:57 AM
Hi Chris,
Ideally the recommendation is to replace it with broadcom phy (BCM5241XA1KMLG) part if you have access to it.
You can find recommended PHYs in the following appnote from Beckhoff: PHY selection guide
But we do not guarantee that you can replace the phy and get it working without any additional changes as its not tested.
Vasanth
Vasanth
12:57 AM
May 28, 2021
12:57 AM
Hi Chris,
Vasanth
Vasanth
