EtherCat example code for KIT_XMC48_IOT_AWS_WIFI
wdc1234
I am looking for example code for KIT_XC48_IOT_AWS_WIFI. I want to run a basic ethercat slave. I can't find any code I tried to migrate Relax 144 pin version that does not seems to work.
Any help would be very welcome.
Pradeep_PN
250 sign-ins 100 solutions authored 25 likes received
Hi @wdc1234 ,
We see that you have already gone through Ethercat Slave Example on 144 pin package controller, If not please refer to the below Link.
Link : https://www.infineon.com/dgdl/Infineon-Getting_Started_%20XMC4800_Relax_EtherCat_APP_Slave_SSC_Examp...
What are the problem you are facing when you are trying to migrate to KIT_XMC48_IOT_AWS_WIFI  ?
Best Regards
Pradeep.
wdc1234
Hi
The development board I have has 100 pin device. I had to move all the pins to the same pin as (XMC4300 relax board) this is also on the schematic. The code compiles. Put when I plug the board into my PLC Master. No of the light on the RJ45 come on and the device can't be seen by TwinCat3 PLC.
David
Pradeep_PN
Hi @wdc1234 ,
Apologies for the delayed response.
Can you please share the migrated project we need to check the Ethercat Pin Mapping.
Best Regards
Pradeep.
Pradeep_PN
Hi @wdc1234 ,
Thread was locked due to inactivity for long time, you can continue the discussion on the topic by opening a new thread with reference to the locked one. The continuous discussion in an inactive thread may mostly be unattended by community users.
Thanks and Regards,
Pradeep
